Thread: elevation target arrow head for spot elevation
    2010-04
    134
    Default elevation target arrow head for spot elevation
    I would like to use an elevation target that is filled as opposed to the open (unfilled) elevation target that is provided. is there a way to change it out or add the filled elevation target head to the list of arrow heads.
    my ultimate goal is to have the target symbol be at the actual location where the elevation is taken from when using the spot elevation.
    2008-11
    Australia
    754
    Default Re: elevation target arrow head for spot elevation
    You can edit the default spot elevation tag.
    To find it, place a spot elevation, select it and in properties click "modify type".
    Under graphics is a category called "symbol" and have a look what the symbol type is called here (it will probably be M_Elevation Annotation, or something similar).
    Once you have noted the name, close the modify properties dialogue.
    Then in your project browser, scroll down to "families" and under "annotation symbols" you will find the annotation symbol with the name you just noted.
    Right click here, and "edit" and this will open the family editor for that family object. Now you can draw whatever you like in its place, make sure you "save as" under a different name.
  1. 2016: REVIT 2016: Spot elevation/Invert elevation for fabrication part.
    By swapr78 in forum Revit MEP - General
    Last Post: 2015-07-03, 11:52 AM
  2. 2014: Spot Elevation with Boxed elevation text
    By kchenault in forum Revit MEP - General
    Last Post: 2014-02-27, 05:20 PM
  3. 2012: Spot elevation and level head show 2 different values
    By 1966ford in forum Revit Architecture - General
    Last Post: 2011-11-07, 09:54 PM
  4. elevation tag / spot elevation tag location
    By frank.richarz in forum Revit Architecture - General
    Last Post: 2010-06-09, 02:30 PM
  5. Civil - Grade Arrow DB, Spot Elevation DB
    By Chris.N in forum Dynamic Blocks - Sharing
    Last Post: 2006-05-02, 06:22 PM
