Thread: Adjusting Alignment Starting Point
    2008-12
    New Jersey
    472
    Default Adjusting Alignment Starting Point
    I have an alignment that I started 0+00 at the entrance to my subdivision. The engineer wants me to adjust the alignment to the centerline of the existing road. How can I extend the alignment to the centerline and give it a negative value. Say it's 30 feet to the centerline so my alignment would read -0+30.00 then start at 0+00 at my entrance.
    Cairo - no, not Illinois
    5,069
    Default Re: Adjusting Alignment Starting Point
    i'll presume that the current starting segment is a straight line.
    stretch the alignment to the cl of existing road, <<if i care about the actual distance and don't want any numbers to shift, i'll out a circle at my desired distance centered on my known point>> then right click on the alignment and choose alignment properties, on that dial log, pick the Station control Tab, and set the station for the Reference point to be -0+30.
    As a general rule, i find i simplest to start my road alignments at the far RoW, and rarely start at a station less than 1+00
    2009-11
    5,719
    Just be mindful of the affect that extended crossing alignments will yield when modeling corridor intersections... As an example, this will result in a four quadrant (four-way) intersection in lieu of a two quadrant (T) intersection.
    Cheers
    Computer Specs:
  1. Specific point on alignment
    By martyk in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-09-25, 04:55 PM
  2. hatch starting point?
    By Wagurto in forum Revit Architecture - General
    Last Post: 2010-08-18, 09:02 PM
  3. Filled Region & Starting point
    By gtakayama in forum Revit Architecture - General
    Last Post: 2010-01-28, 09:06 PM
  4. Alignment starting point
    By Civil-Tech001 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2008-01-07, 04:36 AM
