I have pad footings that are scheduling the incorrect elevation at bottom.
It's out by 7/8".
The pad footings show at the underside of the slab where they should be.
If I dimension from the reference level, (top of foundation and project base point 0.0) I get a different dimension than is scheduled. BIG problem.
I've been reading that this is somehow changed when the footings attach to a column or grade beam. Any solution?
