Thread: Flexnet - Inquiring users of certain programs
    2012-02
    97
    Default Flexnet - Inquiring users of certain programs
    Hi
    Is it possible to inquire users / used licenses for certain Autodesk product using lmutil lmstat ..+attributes? I know I can get all users from server to a text file using:
    lmutil lmstat -a @servername >C:\licenses.txt
    But result is quite long since I'm only interested in one program.
    2015-12
    2,095
    Default Re: Flexnet - Inquiring users of certain programs
    From the command line, I'm not sure. I've always used the dialog UI for inquiries in the past, but JTB tools does a much better job now.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2012-02
    97
    By UI dialog do you mean LMTOOLS.exe? I tried that one too, but I didn't figure out what was the correct query to do there in order to get users.
  1. FLEXnet Licensing error:-13,66
    By nemeth.zoli in forum Revit MEP - General
    Last Post: 2010-08-06, 05:30 PM
  2. FlexNet как служба ! ! !
    By Jokerock in forum Русский - AutoCAD
    Last Post: 2008-10-10, 08:58 AM
  3. Windows XP - add/remove programs only shows programs listed with "A" after ACAD 2002 installation
    By marc.griffies in forum Operating Systems
    Last Post: 2006-08-08, 05:23 PM
  4. FLEXnet/FLEXlm manuals and downloads
    By Mike.Perry in forum Networks
    Last Post: 2006-07-26, 02:42 AM
  5. FLEXnet License Issue
    By Wolfgirl in forum Networks
    Last Post: 2005-11-24, 06:17 AM
