Results 1 to 9 of 9
Thread: Autocad civil 3D crashes when I open layout tab
    2014-04
    2
    Default Autocad civil 3D crashes when I open layout tab
    every time I open auto cad in a layout tab or if I am in model space and I switch to a layout tab it crashes. I have my PICKFIRST set to #1 so I don't see why its crashing. also when I start up civil 3D my start up image is different then everyone else in my office its a foot ball stadium instead of a city a bridge and a river. i feel like that might have something to do with a reason of why it would crash.
    Earth
    9,805
    Default Re: Autocad civil 3D crashes when I open layout tab
    Quote Originally Posted by nathan.hogle624633 View Post
    Pickfirst = 0 doesn't cause crashes, not sure why you'd think that.
    So you're getting this image....
    ...instead of this one?
    The first image is for AutoCAD only.
    R.K. McSwain | CAD Panacea |
    2014-04
    2
    yes that is correct I have that stadium. and when I open auto cad I am opening AutoCAD Civil 3D 2013.Im not sure if it is related at all to my auto cad crashing at all.
    Cairo - no, not Illinois
    5,069
    I'd suggest doing complete uninstall, clean up the hard drive and get rid of as much cruft as you can, and then do a fresh install of c3d
    see http://knowledge.autodesk.com/suppor...rocedures.html
    2009-11
    5,719
    Perhaps it would be prudent to first check that the OP's Application Icon has the appropriate profile specified in the Target Path, no?
    Cheers
    Computer Specs:
    5,069
    I _think_ the splash graphic is hardwired to the executable. Regardless of the selected profile, when I start Civil3d, (whether as c3d or 'civil3d as autocad') I get the c3d splash.
    2009-11
    5,719
    FWIW -
    This is the splash I get when launching the OOTB 'Autodesk AutoCAD Civil 3D as AutoCAD 2014' application icon:
    Computer Specs:
    2014-02
    Quote Originally Posted by nathan403 View Post
    If I'm not mistaken, the Football stadium is 2012 or 2013 release of AutoCAD. That just means you are using a later version. It doesn't have anything to do with the operation or functionality of the software at all.
    Earth
    9,805
    Quote Originally Posted by jrember View Post
    The OP is using Civil 3D which does not use the soccer/football stadium as the splashscreen.
  1. 2008: Autocad 2008 crashes on dwg 2007 open
    By Phil Gravel in forum AutoCAD General
    Last Post: 2011-07-05, 10:55 AM
  2. Replies: 0
    Last Post: 2010-04-01, 03:21 PM
  3. Open files created in Civil 3D with Standard AutoCAD
    By paulr.230726 in forum AutoCAD Civil 3D - General
    Last Post: 2009-10-05, 05:34 PM
  4. Save/Open crashes CAD
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2008-12-05, 04:25 PM
  5. AutoCAD 2005 crashes when trying to open a sheet set linked drawing
    By RICHARD_JONES in forum AutoCAD Sheet Set Manager
    Last Post: 2006-09-01, 07:53 AM
Tags for this Thread
