Thread: Viewport freeze
    2004-06
    Slidell, Louisiana
    964
    Default Viewport freeze
    I recently upgraded to 2015 from 2014. Correct me if I'm wrong, In 2014 I thought when you were in floating model space and turned off a layer it automatically viewport froze that layer. That doesn't seem to be the case in 2015. Is there a setting somewhere or is it just not that way anymore.
    2004-06
    Slidell, Louisiana
    964
    Default Re: Viewport freeze
    Sorry, after a little more investigation I found the setting. select layoff, then s for settings....
    2001-12
    St. Louis
    5,400
    Quote Originally Posted by rmk View Post
    Thanks for taking the time to post back your solution.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Freeze in All Viewport Except Current
    Last Post: 2015-01-05, 03:52 AM
  2. -Layer Freeze/Thaw in Viewport
    Last Post: 2014-09-24, 04:03 AM
  3. 2012: layoff does freeze in viewport
    By rwright363377291 in forum ACA General
    Last Post: 2013-05-03, 04:57 PM
  4. Freeze individual Objects in Viewport
    By chris4455 in forum ACA Wish List
    Last Post: 2011-09-28, 06:54 PM
  5. freeze or thaw in current viewport
    By e.jansen in forum AutoCAD General
    Last Post: 2009-09-16, 09:34 AM
