Thread: how to replace only a single string by pre decided string.
    2014-04
    Post how to replace only a single string by pre decided string.
    Hi....
    My query is that I want to replace the value of a pre decided string to a single string by clicking on it. Find and replace is not useful for this because it replaces all strings. For example in autocad drawing any text is given and by clicking on this text it should be replaced by pre decided text "xyz" (for example).
    Thanks in advance!!!!!
    2013-08
    23
    Default Re: how to replace only a single string by pre decided string.
    (if
      (vl-string-search
        "<Unique Identifier>"
        (setq txt1
          (vlax-get-property
            (setq ent1
              (vlax-ename->vla-object (car(entsel "\nSelect Text:\t")))
          'textstring)
      (vlax-put-property ent1 'textstring (strcat "<Your Text Stuff Here>" "<More Stuff>"))
    You could put a test at the if function to test that it is at the beginning of the string if it's not a unique identifier (i.e. it could appear in the text after it, false positives). Yes it could be more robust, testing for nil entities etc, but that will get you started.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,685
    Quote Originally Posted by mohammad.raees637333 View Post
    Hi....
    Find and replace gives the options to Replace or Find Next as well as Replace All. What version are you using?
    2009-11
    5,732
    I am unsure if you intentionally requested to select each-and-every-single text entity one-at-a-time or not, so this will allow you to do that, or select multiple text entities at once:
    (defun c:FOO (/ *error* acDoc)
      (defun *error* (msg)
        (if	acDoc (vla-endundomark acDoc))
        (cond ((not msg))							; Normal exit
    	  ((member msg '("Function cancelled" "quit / exit abort")))	; <esc> or (quit)
    	  ((princ (strcat "\n** Error: " msg " ** ")))			; Fatal error, display it
        (princ)
      (if (ssget "_:L" '((0 . "TEXT,MTEXT")))
        (progn
          (vla-startundomark
    	(setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
          (vlax-for	x (vla-get-activeselectionset acDoc)
    	(vla-put-textstring x "xyz")
      (*error* nil)
    Computer Specs:
  1. String Parameters & Field Functionality in a Single Block
    Last Post: 2014-08-18, 04:45 PM
  2. How do I replace part of a string?
    By aaronic_abacus in forum AutoLISP
    Last Post: 2009-12-12, 06:24 PM
  3. Replies: 0
    Last Post: 2008-05-22, 08:49 PM
  4. Find string in drawing and replace with VBA
    By montana.fox in forum VBA/COM Interop
    Last Post: 2006-03-01, 04:51 AM
  5. find and replace removing first letter string
    By tyeelaw13 in forum AutoCAD General
    Last Post: 2005-05-03, 04:20 PM
