All,
I am trying to refine our process for doing volume calculations. I am wondering if it is possible to calculate cut and fill volumes from referenced models in a host model.
I created three .DWG's. One with a flat surface, a second with a mounded surface and a third into which I XREFFED the other two. I made sure that the elevation for the flat surface met the bottom of the mound and then created DATASHORTCUTS from the two referenced files. I can see them listed in the host .DWG and can choose them as surfaces when I run the REPORTSURFACEVOLUME command. The cut is 0 which I would expect, but the fill is also 0.
Is it possible to do this kind of calculation across referenced files? Am I missing some small nuance that makes all the difference?
Thanks in advance,
Jeff
