Thread: Startup Suite
    2015-10
    215
    Default Startup Suite
    I have several programs in my startup suite. But, I don't always want them loaded, for instance when I'm working on a client with which I don't need them or when batch publishing. Is there a particular file that contains the startup suite information I can move move and then move back when I want it?
    AutoCAD 2014
    Windows 7
    2005-06
    in the upper right corner
    3,305
    Default Re: Startup Suite
    You should look into creating an Acaddoc.lsp to have your programs loaded.
    Then you can choose which ones to "demand load" by thier commands.
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    Earth
    9,802
    IIRC, the list in the startup suite is stored in the registry.
    You could create a different profiles (I think the "ss" is profile independent), and/or use "Acaddoc.lsp" to load your startup files - which you can manage in a few different ways.
    R.K. McSwain | CAD Panacea |
  1. STARTUP SUITE PROBLEMS
    By jayhay35365091 in forum AutoLISP
    Last Post: 2014-03-03, 04:13 PM
  2. Startup Suite Not Working
    By jchavez76 in forum AutoCAD Customization
    Last Post: 2010-10-08, 12:09 PM
  3. VBA and Startup Suite
    By mboyer in forum VBA/COM Interop
    Last Post: 2007-01-16, 09:26 PM
  4. Startup Suite
    By dmarcotte4 in forum API Wish List
    Last Post: 2006-11-02, 04:19 AM
  5. Startup Suite and Profiles
    By mjsregister in forum VBA/COM Interop
    Last Post: 2004-06-28, 12:06 PM
