Thread: Interop.RobotOM.dll for different Robot versions
    Default Interop.RobotOM.dll for different Robot versions
    Is there a difference between the Interop.dll files between different Robot versions? I've just installed version 2015 and while looking at the SDK I've noticed that two of the samples have Interop.dll files with different file sizes.
    - RobotSDKSample_Reinforcement has an Interop.RobotOM.dll file that is 1492kb
    - RobotSDKSample_Steel has an Interop.RobotOM.dll file that is 1464kb
    Which is the more up-to-date code? And is there any difference to the .dll files to include the new features of 2015?
    2009-11
    32
    Default Re: Interop.RobotOM.dll for different Robot versions
    As a workaround you can manually add a reference to robotom.tlb (typically located in "c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2015\System\Exe\robotom.tlb"). This will create correct Interop.RobotOM.dll
  1. CP308-4: AutoCAD VBA to .NET Migration: The Easy Way Using COM Interop
    Last Post: 2014-12-01, 01:49 AM
  2. Cannot embed interop type
    By michael.montagne in forum Dot Net API
    Last Post: 2012-05-23, 05:29 AM
  3. ACAD COM Interop, accessing attributes
    By ramanujan_ag in forum Dot Net API
    Last Post: 2010-06-26, 05:21 AM
  4. InterOp libraries for Autosketch R7 and above
    By dean.richardson143255 in forum Dot Net API
    Last Post: 2007-07-18, 04:01 PM
  5. R9 interop acad allow this?
    By Vincent Valentijn in forum Inventor - General
    Last Post: 2004-09-09, 02:17 PM
Tags for this Thread
