Thread: Floors and view filter not working as expected
    2002-09
    Madison, WI
    5,688
    Default Floors and view filter not working as expected
    I have a floor plan that has a lot of platforms associated with it. I tried to find the sweet spot with the view range but that didn't help, so I went to view filters.
    I've assigned a parameter to the view filter and to the floor and the beams that support it. But it doesn't seem to be working correctly.
    The beams don't display but the floor does. They both have the same parameter setting. I even did a copy and paste just to make sure everything was done correctly.
    Any idea why a floor object isn't behaving as expected with a view filter applied?
    Thanks in advance.
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Floors and view filter not working as expected
    OK - stupid question; are you certain that the Floors Category is included in your View Filter? Otherwise, can you recreate this behavior in a new Project file and/or post a sample?
    2002-09
    Madison, WI
    5,688
    Man I like stupid questions. Especially when they are the right ones to ask.
    Thanks. I just needed the kick to the head.
  1. 2012: -PAN with coordinate entry not working as expected
    By Steve_Bennett in forum AutoCAD General
    Last Post: 2014-06-19, 07:11 PM
  2. 2013 Boolean subtract not working as expected
    By skyeg3206316 in forum 3ds Max - General
    Last Post: 2014-03-31, 07:44 AM
  3. Active view level filter is not working
    By some buddy in forum Revit - API
    Last Post: 2009-10-02, 02:54 PM
  4. Point (co-ordinate) filter not working as expected
    By sarahjane in forum AutoCAD General
    Last Post: 2005-11-15, 06:59 PM
