Results 1 to 1 of 1
Thread: Moving points
    2016-01
    19
    Default Moving points
    When the field crew started the Back of Walk line it came, into the drawing, past the Face of Curb. This was due to the C3 command that created an arch on the Curb line. I moved the point and the tin lines and contours followed. Yet the small circle remains and I cannot get it to move. Why did it not move with the point marker? Will the circle have any effect on the drawing?
  1. Moving Points and updating point database
    By SJCAN in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-07-18, 07:51 PM
  2. Moving a large number of points
    By scott.epp in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-09-10, 01:26 AM
  3. Moving Survey Points
    By courtlandtgross in forum Revit - Platform
    Last Post: 2010-02-09, 01:02 AM
  4. Moving or copying half distance of your pick points
    By ReachAndre in forum AutoLISP
    Last Post: 2007-03-08, 02:49 PM
  5. Moving points from one surface to another
    By jmartin.127555 in forum Land Desktop - General
    Last Post: 2007-02-14, 11:51 PM
