hi all,
i want to get a print copy of Plot style Table. is it possible to copy Plot Style Table to Excel. Thanks in advance for your support and cooperation.
regards,
Refiq.P.V.
hi all,
regards,
Refiq.P.V.
Hi Refiq.P.V.
Please note I've *moved* this thread from the CAD Mgmt. General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Last edited by Mike.Perry; 2005-03-03 at 10:47 PM. Reason: Correct bad formatting.
Hi
Check out the following thread -
Utility to compare plot style tables
Have a good one, Mike
Hi Mike,
I opened TablePrint(GUI). I click on select tableprint exe in Configure menu and after click on open plotstyle from file menu it shows two messages.
1. Unable to locate component
This application has failed to start because plotcfg8.dll was not found. Re-installing the application may fix this problem.
the second one
2. Can not Open file C:\Documents and..\...\..\..\temp.txt
we are here using AutoCAD 2002. is this problem with this version? or tableprint supports only any later versions. please help me.
Hi
The below snippet it taken from the authors web site of TablePrintGUI -
<snip>
Tableprint is an "unsupported support" tool for AutoCAD (2000i and up) that can be used to "export" the plot style data to a format that can be imported in spreadsheet programs like Excel and Lotus 123. This GUI continues where the Autodesk developers of Tableprint stopped. It allows you to view a plot style in a tableview and print it, without the use of another program like Excel.
</snip>
As you are using AutoCAD 2002 have you also unzipped the contents of tableprint7.zip and run the EXE file contained inside?
Last edited by Mike.Perry; 2005-03-04 at 10:02 AM. Reason: Additional information added.
Thanks Mike. Now it works. I appreciate your support and cooperation. Thanks AutoCAD.
regards,
