Thread: Camera view with no perspective not Rendering correct colors
    2014-05
    Default Camera view with no perspective not Rendering correct colors
    Hello,
    I need to render the elevations of my building and when I create a 3D camera view with no perspective and capture the whole elevation, I set it to render in the Autodesk 360 Cloud Render. The colors render incorrectly and very washed out but if I create a 3D camera view with perspective, it renders in the cloud with the correct colors. Also, the two views have the exact same lighting, sun, and shading settings. I would just create 3D perspective views to render the elevations, but the whole elevation is not seen due to distortion because it is a perspective view. Any solutions?
    Thanks!
    2013-08
    Ottawa, Canada
    5
    Default Re: Camera view with no perspective not Rendering correct colors
    What happens if you render an elevation view? Don't use a camera, just create an elevation of the side you want and render that image?
    2015-12
    102
    I realize that this question was posted several years ago, but here's the answer. Since Revit does not render 2D views -- not elevations, not sections, not plans -- the solution is to create a 3D view that looks like a 2D one.
    1. In an orthographic 3D view, use "Orient to a Plane" to aim the camera directly at the appropriate facade wall. This creates a straight-on 3D view.
    2. Set the view scale and crop as needed.
    3. Render!
  1. Replies: 5
    Last Post: 2011-12-28, 05:30 PM
  2. Camera correct modifier
    By russoo in forum ACA Wish List
    Last Post: 2010-09-27, 02:43 PM
  3. Extremely slow 3D perspective camera view regen
    Last Post: 2009-08-13, 09:27 PM
  4. 3D View vs. Camera (perspective) View
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2008-02-27, 07:21 PM
  5. Perspective and Orthographic Camera Views as View Reps.
    Last Post: 2006-06-14, 03:49 AM
Tags for this Thread
