Thread: OFFSET WITH 20% OF MEASURED DISTANCE.
    2015-08
    32
    Post OFFSET WITH 20% OF MEASURED DISTANCE.
    Dear All,
    Please help me on this.
    I am looking for code with following steps
    1) Select object to Offset
    2) pick point P1 & P2 for offset distance
    3) Pick Point on Side to Offset
    and with step 2 I need offset distance 20% of distance between p1 & p2.
    any help will be much appreciate.
    Thanks,
    2010-06
    962
    Default Re: OFFSET WITH 20% OF MEASURED DISTANCE.
    Try this .
    (defun c:Test (/ 1p 2p o s)
      ;;    Tharwat 05.June.2014        ;;
      (if (and (setq 1p (getpoint "\n Specify first point :"))
               (setq 2p (getpoint "\n Specify second point :" 1p))
               (setq o (/ (distance 1p 2p) 5.))
        (while (setq s (ssget "_+.:S:L" '((0 . "*LINE,CIRCLE,ARC,ELLIPSE"))))
          (command "_.offset" o s pause "")
    2015-08
    32
    Thank you so much Mr. Tharwat,
    Exactly i was needed same
    Thanks.
    Quote Originally Posted by Tharwat View Post
    Try this .
    2010-06
    962
    Quote Originally Posted by aijazahmed View Post
    Thanks.
    You're welcome
  1. Reset Offset Distance
    Last Post: 2020-01-17, 04:50 PM
  2. 2010: Offset Distance
    By lswinea in forum AutoCAD General
    Last Post: 2011-10-18, 01:35 AM
  3. Profile band for offset distance
    Last Post: 2010-10-06, 01:25 AM
  4. setting offset distance
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-06-06, 08:17 PM
  5. distance and offset along a polyline
    By ccowgill in forum AutoLISP
    Last Post: 2006-05-30, 12:48 PM
