Results 1 to 10 of 12
Thread: -PAN with coordinate entry not working as expected
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default -PAN with coordinate entry not working as expected
    I know there used to be a way I could script using –pan to go a specific distance in x/y and my brain just isn’t digging it up at the moment. HELP! =)
    If I have a viewport zoomed into content inside the white circle, and want to -PAN to the left (negative X) and down (negative Y), how do I do this? I can get the negative Y to work but the minute I try to introduce negative X, it goes the opposite direction I want (to the right). I’m feeling a bit famboozeled right now…
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Re: -PAN with coordinate entry not working as expected
    -pan
    Pick any base point
    @-7131625,-19084729 (be sure to include the @ symbol when specifying a second point)
    That works fine for me in C3D 2012.
    2015-12
    4,730
    Is picking a base point required (or instead, entering a base point from coordinates) or can that be skipped?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by Steve_Bennett View Post
    You can just set the first point at 0,0,0
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,682
    Of course if you know where you want to go you can use zoom center. If there's something you want to look at zoom object may do the trick.
    2002-04
    Colorado
    2,020
    AFAIK you have to specify a base point by either picking, typing coordinated or even using the @ symbol.
    The prompt "Specify base point or displacement:" is misleading. It indicates you can provide a displacement but I could not figure it out.
    2004-06
    Slidell, Louisiana
    977
    I'm using Autocad 2015. if I do a -pan and select a basepoint, if I type in @-x,-y it goes to the right and up, if I use @x,y it goes to the left and down. just the opposite of what you think it should do. why is that? is there a setting or sysvar that can be changed?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by rmk View Post
    Well, the obvious thing is to go to (type) UNITS and make sure the "Clockwise" box is not checked. [That's in 2013, I doubt that 2015 is different.]
    2001-03
    Tallahassee, FL USA
    3,682
    As the "Specify base point or displacement:" command prompt suggests you can enter a displacement then simply enter at the "Specify second point:" prompt. Probably the best option since Relative/Absolute input format switches when Dynamic Input is toggled on/off. No need to check the value of dynpicoords that way.
    2007-11
    102
    It is doing what you are telling it to do. Start -Pan and pick a start point and an end point. Your second point might be to the right of your first pick and the screen pans to the left.
  1. 2012: Snap overrides coordinate entry and grip edits
    By jrb63 in forum ACA General
    Last Post: 2014-09-04, 04:42 PM
  2. Direct coordinate entry
    Last Post: 2008-12-15, 04:23 PM
  3. coordinate entry variable precision
    By Aston in forum AutoCAD Tips & Tricks
    Last Post: 2008-05-24, 01:06 PM
  4. Coordinate Properties and Entry Method
    By peter in forum Revit Structure - Wish List
    Last Post: 2005-12-12, 10:09 PM
