Results 1 to 8 of 8
Thread: Project Navigator Sheets Disappearing
    2013-09
    15
    Default Project Navigator Sheets Disappearing
    I am working on setting up the sheets of a new project in PN. This is my first real project using PN. When I create a new subset and then create a sheet in that subset, it will open the sheet and I can manipulate it and do everything I need to. When I close it, and try to reopen it later, it has mysteriously disappeared in PN along with the subset it is in. Also, the default architectural subsets and sheets that I have deleted have all reappeared. See the attached snapshot to see what defaults are coming in. This has happened multiple times now. I tried repathing the project but for some reason PN wont even let me do that anymore. That just started happening when I started creating these sheets. Any suggestions would be appreciated.
    2013-09
    15
    Default Re: Project Navigator Sheets Disappearing
    I am still having this problem. I cant even create a sheet anymore without this box coming up. I have attached another screenshot showing what box is coming up. Please help!!! I dont want to have to create a whole new project to fix this.Sheets Issue.JPG
    2001-12
    St. Louis
    5,408
    Since all of my users have always had vanilla, I never got into the habit of using the PN myself, stuck with plain old sheet sets. But, my first thought is a network connectivity or backup thing.
    Are you working off a central server? Any chance the modified files are being overwritten by a backup restore done by IT? or, regarding the second error there, any chance you're experiencing connectivity issues where you're logged off of the network and then have to log back in... that could throw an error and result in data loss.
    Aside from that, I'm not certain what it could be.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2013-09
    15
    I have checked to see if any of the files have been overwritten. The weird thing is that the files never even make it to the folders. It's like they were never even created. Then that message pops up and I cant even navigate away from the sheets tab. I have to close autocad out completely, open it back up, and refresh the project. Only then can I quickly open PN and go back to the constructs tab. I have to do it quickly though or else that message pops up and I have to do it all over again.
    2013-09
    15
    I am having an issue creating sheets in Project Navigator. When I go to the sheets tab in PN a message pops up that says "Cannot find the data. The sheet set may have been changed by others. Please refresh the project." and it wont allow me to create a subset or sheet. I have tried refreshing the project, closing the project and refreshing it. I have found a previous version of the .dst file and replaced the current one. I have tried everything I could think of. Can any one help me get this to go away? I have attached a screenshot of the message.
    2007-03
    9
    Quote Originally Posted by JHARSH View Post
    When I see messages like this its always due to the dst file being in use or locked somehow.
    Check the projects dst file size and modified date, then add some sheets and check the date and size of the dst file, did either change?
    If so then it appears that the dst file can be written to.
    How about the sheet folder(s), can they be written to, are the files for the new sheets you are making showing up in them?
    There should be 3 files for each sheet you have, dwg, bak and xml.
    The xml file is important because if you don't have it for a particular sheet then that sheet wont appear in the PN even if there is a dwg file for it
    Before trying the following make a backup copy of the entire project!!
    As a last resort you can try closing MEP and deleting the projects dst file. It will be recreated the next time you start MEP and load the project, you will see a "Sheet Set Warning" dialog telling you that a new sheet set will be created".
    2011-05
    I have used the Project Navigator in AutoCAD Architectural since 2006. I create my own sheet sets off of a basic sheet set with my Custom Title block in it that has things automatically populated for me on each sheet. I know that you can not use a different release version of a sheet set and have it work. Example you can not use a 2013 sheet set while using 2014. I have to set my custom sheet sets up every time I load the new version.
    I would want to see the views tab and your project Browser showing your projects and see that the current one you are working on is in bold (which means that it is the current project).
    Next I would make sure that in the views tab I have selected the model space view of the project or part of the project that I am working on. Then look at your sheet set and make sure that all those plus signs to the left side of the different categories have been clicked and expanded to see what is behind it.
    Another check you can do is to go to your Crive or what ever drive you have your CAD files on and under My Documents then Autodesk select My Projects go to the project you are having problems with and look at the sheets and see if they show up. If you have multiple files that show up click on each one to see what is there.
    Have you sent a support request to Autodesk direct from inside the file? They have always been a great help when I ran into problems because then are working with your file and can see what happened to it.
    Brent
    2008-01
    Quote Originally Posted by brentnbutler934974 View Post
    Brent
    Why can't you use the same sheet set from a prior version? I've cleaned mine up a bit to remove some unnecessary subfolders but it's the same file. I'm now having issues where a project is started in the "new" version, sheets are set up and then we come back the next day to find the sheets are missing but all the files still exist in windows explorer. This has happened twice in ACAD MEP 2014 since we upgraded a few weeks ago. Any thoughts?
  1. Moving sheets in Project Navigator
    By rmccarty in forum Project Navigator
    Last Post: 2010-08-17, 07:34 PM
  2. Ahhhh - Sheets gone from Project Navigator
    By kevin.bell.72378 in forum ACA General
    Last Post: 2009-12-17, 04:22 PM
  3. Copying sheets in Project Navigator
    By beritsonderbo in forum ACA Wish List
    Last Post: 2008-11-25, 12:30 AM
  4. Project Navigator New sheets Xref
    By james840a in forum Project Navigator
    Last Post: 2008-11-20, 11:19 PM
  5. Project Navigator sheets
    By cbiddulph in forum ACA General
    Last Post: 2005-02-01, 05:11 PM
