Thread: delta radius length tangent lisp
    2013-02
    47
    Default delta radius length tangent lisp
    Hello all,
    I have this lisp routine that i often use but i cannot seam to get it to show 2 decimal places.
    I could use some help with this. thanks in advance.
    here is the routine.
    ;DRLT - annotate Delta, Radius, Arc length, as Label
    (defun cRLT (/ bc radp ec delta rad len brg sdelta srad slen tan stan)
    (getarc)
    (setq brg (angtos delta 1 4))
    (dtod brg)
    (setq sdelta (strcat "" brg)
    srad (strcat "" (rtos rad 2 2))
    slen (strcat "" (rtos len 2 2))
    (setq tan (/ (sin (* delta 0.5)) (cos (* delta 0.5))))
    (setq stan (strcat "" (rtos (* rad tan) 2 2))
    scord (strcat "C=" (rtos (* 2 rad (sin (* delta 0.5))) 2 2))
    (command "TEXT" pause pause sdelta)
    (command "TEXT" "" srad)
    (command "TEXT" "" slen)
    (command "TEXT" "" stan)
    (princ)
    2005-06
    in the upper right corner
    3,507
    Default Re: delta radius length tangent lisp
    I couldn't make this routine work, and I couldn't figure out why.
    Please use code tags.. it will help avoid smileys
    (defun c:DRLT (/ bc radp ec delta rad len brg sdelta srad slen tan stan)
    (getarc)
    (dtod brg)
    (setq sdelta (strcat "" brg) srad (strcat "" (rtos rad 2 2)) slen (strcat "" (rtos len 2 2)))
    (setq stan (strcat "" (rtos (* rad tan) 2 2))scord (strcat "C=" (rtos (* 2 rad (sin (* delta 0.5))) 2 2)))
    (princ)
    Anywho...
    I would suspect the decimal thing will be controlled in your drawing units, so that could be set in your code too.
    2001-03
    Tallahassee, FL USA
    3,667
    I attached an old routine that labels lines & arcs inserting a block with attributes with the text height matching the textsize variable. Put the lisp & drawings in the support path.
    2002-08
    231
    Hi,
    My version ARTDB (in french: Angle at vertex, Radius, Tangent, Development Cord, B against arrow?) for annotate arc info of polyline
    If can help you?
    (vl-load-com)
    (defun c:ARTDB ( / js n AcDoc Space ename obj pr nb typ_obj oldim oldlay a_base a_dir
     pt_start pt_end pt_cen rad alpha pt_vtx dist_start dist_end seg_len seg_bulge)
      (defun grdraw-id_arc ( / )
        (grdraw (trans pt_start 0 1) (trans pt_vtx 0 1) 1)
        (grdraw (trans pt_vtx 0 1) (trans pt_end 0 1) 1)
        (grdraw (trans pt_start 0 1) (trans pt_cen 0 1) 3)
        (grdraw (trans pt_cen 0 1) (trans pt_end 0 1) 3)
      (defun add_mt_arc ( / ins_txt h_t)
        (initget 9)
        (setq ins_txt (getpoint (trans pt_cen 0 1) "\nPoint d'insertion des informations de l'arc?: "))
        (initget 6)
        (setq h_t (getdist ins_txt (strcat "\nTaille du texte <" (rtos (getvar "textsize")) ">: ")))
        (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t))
        (vla-addMtext Space
          (vlax-3d-point (trans ins_txt 1 0))
          0.0
          (strcat
            "{\\fArial Narrow|b0|i0|c0|p34;"
            "A = " (angtos (- pi (* 2 alpha)) 0 4) "%%d"
            "\\PR = " (rtos rad 2 3)
            "\\PT = " (rtos (distance pt_start pt_vtx) 2 3)
            "\\PD = " (rtos seg_len 2 3)
            "\\PB = " (rtos (- (distance pt_cen pt_vtx) (abs rad)) 2 3)
        (entmod
          (append
          (vl-remove-if
            (function
              (lambda (x)
                (or (member (car x) '(90 63 421 45))
                  (< 419 (car x) 440)
            (entget (entlast))
          (list
            '(90 . 1)
            '(63 . 41)
            '(421 . 16770196)
            '(45 . 1.5)
        (entupd (entlast))
      (princ "\nSélectionner des Arcs/PolyArcs .")
      (setq
        js
        (ssget
          '((-4 . "<OR")
            (-4 . "<AND")
              (0 . "POLYLINE")
              (-4 . "<NOT")
                (-4 . "&") (70 . 126)
              (-4 . "NOT>")
            (-4 . "AND>")
            (0 . "LWPOLYLINE,ARC")
            (-4 . "OR>"))
        n -1
      (cond
        (js
          (setq
            AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
            Space
              (if (= 1 (getvar "CVPORT"))
                (vla-get-PaperSpace AcDoc)
                (vla-get-ModelSpace AcDoc)
            nb 0
          (cond
            ((null (tblsearch "LAYER" "Info ARTDB des Arcs"))
              (vlax-put (vla-add (vla-get-layers AcDoc) "Info ARTDB des Arcs") 'Color "5")
          (setq
            oldim (getvar "dimzin")
            oldlay (getvar "clayer")
            a_base (getvar "ANGBASE")
            a_dir (getvar "ANGDIR")
          (setvar "dimzin" 0) (setvar "clayer" "Info ARTDB des Arcs")
          (setvar "ANGBASE" 0) (setvar "ANGDIR" 0)
          (repeat (sslength js)
            (setq
              ename (ssname js (setq n (1+ n)))
              obj (vlax-ename->vla-object ename)
              pr -1
              nb 0
            (setq typ_obj (vla-get-ObjectName obj))
            (if (eq typ_obj "AcDbArc")
              (progn
                (setq
                  pt_start (vlax-get obj 'StartPoint)
                  pt_end (vlax-get obj 'EndPoint)
                  pt_cen (vlax-get obj 'Center)
                  rad (vlax-get obj 'Radius)
                  alpha (* (vlax-get obj 'TotalAngle) 0.5)
                  seg_len (vlax-get obj 'ArcLength)
                  pt_vtx (polar pt_cen (+ (vlax-get obj 'StartAngle) alpha) (+ rad (* rad (1- (/ 1 (cos alpha))))))
                  nb (1+ nb)
                (grdraw-id_arc)
                (add_mt_arc)
              (repeat (fix (vlax-curve-getEndParam obj))
                (setq
                  dist_start (vlax-curve-GetDistAtParam obj (setq pr (1+ pr)))
                  dist_end (vlax-curve-GetDistAtParam obj (1+ pr))
                  pt_start   (vlax-curve-GetPointAtParam obj pr)
                  pt_end (vlax-curve-GetPointAtParam obj (1+ pr))
                  seg_len (- dist_end dist_start)
                  seg_bulge (vla-GetBulge obj pr)
                (if (not (zerop seg_bulge))
                  (progn
                    (setq
                      rad (/ seg_len (* 4.0 (atan seg_bulge)))
                      alpha (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge))))
                      pt_cen (polar pt_start alpha rad)
                      pt_vtx (polar pt_start (- alpha (* pi 0.5)) (* rad (/ (sin (* 2.0 (atan seg_bulge))) (cos (* 2.0 (atan seg_bulge))))))
                      alpha (if (< (* 2.0 (atan seg_bulge)) 0) (- pi (* 2.0 (atan seg_bulge))) (* 2.0 (atan seg_bulge)))
                      nb (1+ nb)
                    (grdraw-id_arc)
                    (add_mt_arc)
          (setvar "dimzin" oldim) (setvar "clayer" oldlay)
          (setvar "ANGBASE" a_base) (setvar "ANGDIR" a_dir)
      (prin1)
  1. Find arc radius given length and chord
    By jodi_sherrell in forum AutoCAD General
    Last Post: 2010-02-15, 02:10 PM
  2. lisp to generate tangent lines for a selected arc
    By vnk17200414 in forum AutoLISP
    Last Post: 2009-12-04, 04:39 AM
  3. Arcs by P.C., arc length, Radius, Tangent bearing, Delta
    By justinxxvii in forum AutoCAD General
    Last Post: 2006-04-29, 10:32 PM
  4. Any way to draw an arc by tangent, tangent, radius?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2005-09-01, 01:49 PM
  5. Dimension Radius Length
    By matt.bauer in forum AutoCAD LT - General
    Last Post: 2004-12-21, 02:28 PM
