Thread: Electric Outlets in Elevation
    Active Member fkellogg's Avatar
    2005-09
    Virginia, via Fayetteville, Arkansas
    92
    Default Electric Outlets in Elevation
    I am back, after a long, dark, depressing spate at a place that only had 2004, and no Dynamic Blocks.
    Now that I have a new job, I can again use DB's!
    I am looking for a Dynamic Block of Electric Outlets, like they would look in elevation in cabinetry.
    I hope to find one with several different types of outlet-box things, like single outlet, quad outlet, light switches, etc.
    Has anyone out there made one yet?
    2004-07
    Baton Rouge, Louisiana
    254
    Default Re: Electric Outlets in Elevation
    are you looking for one block with to have all the these block as a choice or do want to have one block with receptacles, one block with switches etc.
    2008-01
    4
    is this what you are looking for
    Active Member Heather_W's Avatar
    2007-01
    75
    Quote Originally Posted by jdonaldson.158817 View Post
    This is great! I love smart blocks! Is there a way to change to switch block to another name without messing anything up? I've tried but when I did, it stopped allowing more than one switch. (I have another block already named "Switch")
    in the upper right corner
    3,507
    Quote Originally Posted by Heather_W View Post
    Yes there is.... while in the block drawing, simply use the rename command and select blocks, rename "switch" to something else.
    I tested this and it worked, still allowed me to select other switch views.
  1. Outlets Won't Attach to Wall
    By bdumas in forum Revit MEP - General
    Last Post: 2019-01-15, 07:29 AM
  2. 2016: Electrical Outlets, Data Outlets - Report Elevations?
    By mit81 in forum Revit MEP - Families
    Last Post: 2015-08-17, 02:48 AM
  3. 2015: Electrical outlets
    By kslifter in forum Dynamic Blocks - Sharing
    Last Post: 2015-07-09, 08:51 PM
  4. 2012: Dimensioning and Electrical Outlets
    By StacyJennifer in forum Revit Architecture - General
    Last Post: 2011-09-19, 01:38 PM
  5. Switches and Outlets
    By mrdavie in forum Revit Architecture - General
    Last Post: 2011-04-08, 11:18 PM
