Results 1 to 6 of 6
Thread: Reset Offset Distance
    Wish List Administration
    2011-08
    4,581
    Default Reset Offset Distance
    Summary: It would be great to be able to reset an offset distance without having to cancel the current offset command and start the process again.
    Description: It can be annoying to have to back out of the offset command and start it back over just to do a different dimension for the offset distance. It would speed up the drafting time if there was an option for resetting a distance without having to completely back out of the command.
    Product and Feature: AutoCAD - Drawing Tools 2D
    Submitted By: Chante Bright on 06/17/2014
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,481
    Default Re: Reset Offset Distance
    Enter or spacebar twice isn't fast enough? Years ago when you started the offset command it prompted to select a line. You had to enter R to change or even see what the radius was. The current way is a big improvement.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    Earth
    9,802
    In this meantime, download this routine and give it a try.
    http://cadtips.cadalyst.com/linear-o...unning-options
    R.K. McSwain | CAD Panacea |
    2011-08
    4,581
    Exclamation Re: Reset Offset Distance
    Submitted By: cbright.158342 on 06/17/2014
    2011-08
    4,581
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. OFFSET WITH 20% OF MEASURED DISTANCE.
    By aijazahmed in forum AutoLISP
    Last Post: 2014-06-05, 04:12 PM
  2. Offset value reset
    Last Post: 2012-06-18, 10:31 AM
  3. 2010: Offset Distance
    By lswinea in forum AutoCAD General
    Last Post: 2011-10-18, 01:35 AM
  4. setting offset distance
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-06-06, 08:17 PM
  5. distance and offset along a polyline
    By ccowgill in forum AutoLISP
    Last Post: 2006-05-30, 12:48 PM
