Hi! How do you create winder or spiral stairs with Revit?
Thanks!
Rob
I got my spiral stair to work... This is the first time I needed them, I just used the "stair by sketch" and the "arc" tool to create them..
Thanks!
Rob
Last edited by ROBP-RDS; 2014-06-23 at 02:20 PM. Reason: Got the stairs to work...
With the stairs by component, spiral stair is one of the option on the component panel. Same with the winder stair. If you need to modify winders to a different layout, click on ‘convert’ and ’edit sketch’ (tools panel).
Thank you! After reading your post, I looked at the spiral stair option in the component panel... I will give it a try... I appreciate it..
Rob
