Thread: Nested IF statements for Lintel family
    2013-07
    Cleveland, OH
    55
    Question Nested IF statements for Lintel family
    I am trying to make a custom Steel Lintel Family and would like for the extrusion of the angle legs be driven by the Parameter OPENING WIDTH.
    I have most of the family working except the formula portion. I have read on nested IF statements, but I am STILL having issues.
    Right now I have: if (OPENING WIDTH<4', 3 1/2", if (OPENING WIDTH<6', 5"))
    I keep getting the error BAD IF STATEMENT format.
    What I would like to happen is for opening smaller than 4'-0" use a 3 1/2" angle leg and for opening greater than 4'-0" but smaller than 6'-0" use a 5" angle leg. Eventually I do want to add a thir condition to the statement, but if I can't get this to work expanding on it is hard.
    Where am I going wrong? Thanks for the assistance.
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Nested IF statements for Lintel family
    IF/THEN/ELSE statements need all three arguments to be valid. Your statement is missing a final ELSE statement, which would be what occurs if no other conditions are met.
    Your formula: if (OPENING WIDTH<4', 3 1/2", if (OPENING WIDTH<6', 5", ELSE))
    All you have to do to correct your formula is enter a value you would like to be returned (as the ELSE argument) if OPENING WIDTH is greater than or equal to 6'.
    Corey D.Please let the saying "The only stupid question is the one not asked" not be seen as a challenge to defy it.
    2013-07
    Cleveland, OH
    55
    Thanks! I will give that a try. That makes sense. This is the first family I have made with nested IF statements.
  1. 2014: Lintel Family
    By kROSEMAN in forum Revit Structure - General
    Last Post: 2014-06-06, 09:39 AM
  2. 2013: Conditional Statements and Nested Families
    By kROSEMAN in forum Revit Structure - Families
    Last Post: 2014-02-10, 10:52 PM
  3. 2014: Nested family cuts wall below midpoint of nested family but not above (in plan)
    By CBroda in forum Revit Architecture - Families
    Last Post: 2013-09-24, 05:27 PM
  4. Nested Boolean Statements in Yes/No Parameters
    By apollodacreed in forum Revit Architecture - Families
    Last Post: 2009-08-05, 07:28 PM
  5. A lintel in section nested within window family
    By bayejid_bd in forum Revit Architecture - General
    Last Post: 2006-02-06, 09:24 PM
