Thread: Autodesk 360 error
    2006-02
    Lake Jackson, TX
    Exclamation Autodesk 360 error
    Students have educational download Revit 2014. When trying to run
    Energy Analysis error: “You do not currently have access to this
    service. Your lic period for the sharing service has ended.” Do
    students get this service?...some are able to run analysis and some
    not. Thank you.
    2001-12
    St. Louis
    5,301
    Default Re: Autodesk 360 error
    Quote Originally Posted by ubedesigns View Post
    not. Thank you.
    There are some suggestions here: http://feedback.autodesk.com/cloudse..._in_revit_2014
    One thing to look at when you are unable to sign in from a desktop product is that your system date, time and country region are set to where you are located.
    Also be sure you are running the latest service pack for Revit as that did resolve some Render as a Service issues.
    If you have a proxy server and firewall that could also be part of the issue. You would want to make sure not only the ports are open but that you have access to the sites listed below.
    *.akamaiedge.net
    *.amazonaws.com
    *.autodesk.com
    *.google-analytics.com
    *.cloudfront.net
    *.getsatisfaction.com
    Firewalls should allow ports 80 and 443 to everything if possible.
    Hmm, considering... I believe I'd heard that Revit rendering is done as a service through 360, but, never looked at the requirements... amount of renders, whether a subscription account or other service is required to use them, so I wonder if Energy Analysis might be the same?
    Oh, looking at their site, that does seem to be the case? http://www.autodesk.com/products/ene...revit/overview
    This service is only available when you purchase a perpetual license with Maintenance Subscription or a Desktop Subscription for select Autodesk software.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
  1. 2012: OCR Text recognition error in Autodesk Raster Design 2013
    By subramanyam.josyula348947 in forum Raster Design - General
    Last Post: 2012-12-27, 12:10 PM
  2. Autodesk Content Service Error
    By Neo_Richard_Blake in forum Software
    Last Post: 2011-07-15, 03:24 PM
  3. Autodesk Content Service Error
    By Neo_Richard_Blake in forum AutoCAD LT - General
    Last Post: 2011-07-14, 03:27 PM
  4. Error on opening Autodesk LDD
    By brobinson164070 in forum AutoCAD Land Desktop - General
    Last Post: 2011-02-14, 04:17 PM
  5. DWG file...not developed...by Autodesk error
    By jrichardson in forum AutoCAD General
    Last Post: 2007-01-08, 01:12 PM
Tags for this Thread
