Results 1 to 10 of 16
Thread: Only one plan callout style possible? What's up with that?
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Default Only one plan callout style possible? What's up with that?
    We're working with a beeeeeg client on a beeeeeg project and we want to have a callout style where the callout head is nothing but a huge letter - this will point to a 1:100 scale callout view of the 1:500 overall plan.
    We can do that... cool, but... you can't duplicate the callout style to make a regular one as well as the one that uses the big letter.
    Am I missing something, or can we only have one callout style for plan views??
    2001-12
    Irvine, CA
    7,567
    Default Re: Only one plan callout style possible? What's up with that?
    Subtle new step involved. Settings | View Tags | Callout tags
    You establish this "style" then you can assign it to a callout. You assign the style to the view. You can only assign one callout style to a view.
    All AUGI, all the time J. Grouchy's Avatar
    2003-12
    Quhl Whirled
    896
    You also apparently can only have one Reference Callout Style. Sometimes I want to say "SIM", sometimes I want to say "O.H." (opposite hand)...but when I try to set up different ones, it always gives me the original I set up under the View Tags dialog. I used to be able to create different ones in 6.1...why the regression?
    2003-04
    Chino, CA
    4,756
    You have to create a new tag by duplicating the original, and then add the SIM or TYP, and name the Tag appropriately.
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by Scott Davis
    The issue is that the VIEW determines the callout used. If you create a detail that you assign a reference callout that uses SIM then anytime you reference that view you get that reference callout style. To get one that allows you to use OPP you actually have to create a new view (might as well BE opposite hand), assign that style to the view. In the past you could just switch the annotation from type to type. The irony is, if you have to create a separate view, you don't need the OPP designation eh?
    2003-12
    Quhl Whirled
    896
    Tried it...doesn't work.
    2003-04
    Chino, CA
    4,756
    Oh yeah, Steve's right! Create a duplicate View Type, called View SIM or something like that.
    2003-05
    3,348
    Quote Originally Posted by Steve_Stafford
    Right - I do have two callout tag styles... but I can't duplicate the floor plan callout style to use the second tag style. Looks like you can only have one callout style for plans in a project. Bummer...
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by Wes Macaulay
    You can...you have to create different view types so you can assign the different callout types to. Each view can only have ONE type assigned however. Confused yet?
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    I think Wes is pointing out correctly that it is not currently possible to make multiple types of plan views. However one can make many types of detail views and detail views can look straight down just like plan views. When making a callout in plan view user can click a down arrow in type drop-down, switch to a detail view and thus gain ability to make new types. Can detail views be used to achieve Wes' goals?
  1. 2013: plan callout scale
    By clintonc in forum Revit - Platform
    Last Post: 2012-10-23, 06:47 PM
  2. 2012: Revit plan callout
    By pya663858 in forum Revit Architecture - General
    Last Post: 2012-02-29, 08:59 PM
  3. Move Plan Callout to New View
    By antman in forum Revit Architecture - General
    Last Post: 2011-12-21, 04:06 PM
  4. plan callout issue
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2007-07-18, 05:33 PM
  5. Callout line pattern/style
    By jr.78265 in forum Revit Architecture - General
    Last Post: 2004-12-14, 04:43 AM
