Thread: Point Groups and how they apply to design sheets, how do I turn some off per sheet?
    2014-02
    4
    Default Point Groups and how they apply to design sheets, how do I turn some off per sheet?
    Hello all,
    I am rather new too civil 3D. I work in a Microstation heavy firm, but am my group's only drafter. I am slowly teaching my self C3D 2014 through the tutorials, blogs, etc.
    The issue I am having, is I am wanting some point groups to show in some P&Ps and others to show in other P&Ps. I understand the point group structure and creating an "invisible" point group so that those points do not show up and having the points I do want to show up being above that "invisible" point group. And this works great for the file(ProjectName_Prop_Points.dwg) I have the proposed points in. However how does this apply to the design files that have my (ProjectName_Prop_Points.dwg) referenced into? How do I have some point groups on and others not on? When I go to Toolspace while in the design files, the point groups are not there for me to manipulate from the xref file.
    Thanks for all the help, cheers.
    Cairo - no, not Illinois
    4,790
    Default Re: Point Groups and how they apply to design sheets, how do I turn some off per sheet?
    Since it's not possible to really DRef points/point groups, I think you'll be stuck with layer manipulation
    2014-02
    4
    Yea figured out the workaround.
    Toolspace --> Prospector Tab --> Point Groups --> Go to Point Group --> Right Click on Point Group where second group of points are --> Properties --> Under Point Label Style, Copy current selection --> Rename Point Group 2 or whatever --> Under the Label tab, change the layer to the desired layer.
    What was getting me in the beginning with this, is I had switched the layers using just the normal properties drop down. But the C3D Point was still under the C-Node layer instead of the one I had switched it to.
  1. Replies: 3
    Last Post: 2013-11-05, 07:51 PM
  2. Survey Figure Groups concept identical to Point Groups.
    Last Post: 2011-11-16, 09:24 PM
  3. Automatic Point Groups (Design)
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2007-09-17, 08:17 PM
  4. Plot a Multi-Sheet DWF with Landscape sheets and Portrait sheets
    By KansasCAD in forum Design Review - General
    Last Post: 2007-05-18, 06:51 PM
  5. turn off groups?
    By Les Therrien in forum Revit Architecture - General
    Last Post: 2004-06-17, 04:06 PM
