Results 1 to 1 of 1
Thread: Inventor 2015 - Sheet Metal -Create Flat Pattern from sweep along path
    2013-08
    Default Inventor 2015 - Sheet Metal -Create Flat Pattern from sweep along path
    Hello there,
    I have a specific problem creating a flatt Pattern from an Sheet Metal Part. My question is:
    Is it possible by the nature of the material and geometry to create such an flat pattern? Notice the Sweep Path has an circular sector. Also the Material thickness and bend Radiuses are set to the correct values. If it is possible, how can I do that , since I'm a newbie to the World of Sheet Metal . Im unable to uplad the Ipt file so i made some pics.
    Thank you
    Armin M.
  1. Replies: 0
    Last Post: 2015-08-07, 05:34 PM
  2. 2011: derived mirrored sheet metal part flat pattern
    By ncrissy in forum Inventor - General
    Last Post: 2011-04-28, 03:21 PM
  3. Create Flat Pattern DXF from Sheet Metal on Check in
    Last Post: 2009-09-21, 09:43 PM
  4. Create Flat Patterns of Sheet metal iParts
    Last Post: 2007-04-24, 04:40 PM
  5. Mirrored Sheet Metal Features Not in Flat Pattern?
    By Mike Y in forum Inventor - General
    Last Post: 2007-01-07, 07:48 PM
