Thread: Need To Change A Color In The Color Index.
    2001-11
    236
    Default Need To Change A Color In The Color Index.
    Just three questions.
    First, I need to change a default AutoCAD's color (249) in the index to a basic color (say color 5 [blue]).
    How can I achieve this?
    Second, if I were to change a color in the index, what would be the negative effect on sharing files?
    Third, what happens when I create an eTransmit (if I have a different color index)?
    Thanks.
    Cairo - no, not Illinois
    5,069
    Default Re: Need To Change A Color In The Color Index.
    Quote Originally Posted by omorah View Post
    Thanks.
    1) can't be done
    2) if it were possible, would result in any recipient of your drawing having something different than you thought you sent.
    3) see 2.
    Which begs the question -- Why would you do this? There's probably another way to get the same result without the negative consequences.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Not sure if it's what you're asking for, but you can set color 249 to plot as color 5 (blue) in a CTB file. To share the file you would need to share that custom CTB file. An eTransmit will allow you to include Plot Styles, fonts, and reference files.
    You could always use blue instead of 249 instead.
  1. Replies: 8
    Last Post: 2015-01-06, 01:15 PM
  2. LISP for change yellow color into Color 8
    By rhodinj1427782 in forum AutoLISP
    Last Post: 2014-01-16, 05:26 AM
  3. AutoCAD Color Index and RGB
    By Kris.Keller in forum AutoCAD General
    Last Post: 2013-02-06, 07:28 AM
  4. AutoCAD Color Index: Index Color List
    By GreenMan415 in forum AutoCAD General
    Last Post: 2008-06-25, 05:36 AM
  5. Index Color to RGB
    By bweir in forum Dot Net API
    Last Post: 2007-02-11, 01:43 PM
