Originally Posted by
bmcelhiney@mecresults.com
Thank you for your responses. Currently the way our model is set up, the corridor regions on the legs end before reaching the circulatory area region. Our circulatory area doesn't include any outer curb lines because they may not reach where the actual inscribed circle is. I know we could probably use a small corridor assembly to run along the curb, but thought it'd be easier to create feature lines out on the BOC to "fill in the gaps" that the corridor isn't reaching. This is no problem since we have elevations to tie into on either end and can easily figure out the curb elevations between. However, I'm seeking an easy way to project from my BOC to front of walk (two lines that are not parallel with one another) and get that slope to be exactly 4%. The elevation from adjacent reference wants to project to the front of walk feature line at strange angles unless I put in a bunch of elevation points on the front of walk feature line. I know I could project elevations to certain elevation points placed on the feature line by hand, but I was hoping for an easier, automated process.
