Results 1 to 6 of 6
Thread: Override a Dimension to show it as a blank value
    2008-11
    Nashville, TN
    Cool Override a Dimension to show it as a blank value
    Have you ever needed to show a dimension string without a value or text? To achieve this, select the dimension and then proceed to override it with text. In the text field; Hold down the "Alt" key and type 030, then select OK.
    You now have a blank dimension.
    Note: ALT030 will not show in the text field when you type it. The field will remain blank.
    2013-07
    Cleveland, OH
    56
    Default Re: Override a Dimension to show it as a blank value
    This is a great tip! Thanks!
    2003-05
    4
    Not working for me - is it font specific (I am using arial).
    2003-05
    4
    2
    Sad to say I am replying to my own post - my natural curiosity led me to this blog, which shows a missing step to the one above.
    http://architects-desktop.blogspot.c...dimension.html
    2003-05
    4
    Discovered another quirk of Revit - the first post will work if you input the numbers using the numeric keypad NOT the regular numbers on the standard keyboard.
    2007-01
    226
    This is not a Revit quirk, this is a Windows quirk. try using regular numbers from keyboard in note pad or other program and you will get the same result.
    Always use numeric keypad for special characters. Do not know what laptop or Mac users do if they do not have numeric keypad on keyboard...?
  1. Replies: 2
    Last Post: 2008-08-20, 12:42 PM
  2. Unused fields need to show as blank
    By eleonard in forum AutoCAD Fields
    Last Post: 2007-10-31, 05:26 PM
  3. Blank Dimension
    By mccurdyks in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-07-24, 08:25 PM
  4. Dimension Override
    By bmccabe.65836 in forum Revit Architecture - General
    Last Post: 2005-03-08, 07:43 PM
  5. Dimension Override
    By bmccabe.65836 in forum Revit Architecture - Tips & Tricks
Tags for this Thread
