Thread: Qleader Spline displays as straight lines
    Default Qleader Spline displays as straight lines
    I created a qleader as a "spline with arrow" (3 points) in one tab and it worked fine.
    I then copied and pasted this spline into another tab and it now displays as straight lines rather than a curve.
    The original leader still displays correctly though.
    The properties still state that it is a "spline with arrow".
    I have tried regenall, saving and restarting autocad 2015 and the issue still remains.
    If I create a new qleader in this tab, the issue remains, i.e. it says it is a spline, but displays as straight lines.
    Has anyone else seen this issue? or can anyone suggest a fix?
    Thanks
    Cairo - no, not Illinois
    4,753
    Default Re: Qleader Spline displays as straight lines
    Use MLeader instead, or delete the Qleader and recreate it instead of copying.
    by 'tab' do you mean drawing, or layout? If the firmer, look at the dimstyles in the destination drawing. Just realize that qleader is spmewhat obsolete and superseded by MLeader.
    Thanks for the reply,
    I had initially restarted autocad which had not fixed the problem, but after restarting my computer (overnight), the issue seems to have fixed itself.
    If it happens again, I will use MLeader instead.
    By tab, I refer to the layout tabs not separate drawings.
  1. 2013: QLEADER-CONTROL VERTICES OF THE SPLINE
    By pmoore433559 in forum AutoCAD General
    Last Post: 2014-01-06, 11:18 PM
  2. Replies: 9
    Last Post: 2012-12-20, 09:50 PM
  3. Straight, Spline, Custom Leader
    By cody.brewer907955 in forum AutoCAD General
    Last Post: 2012-08-22, 01:40 PM
  4. Show topo lines as smooth spline curves instead of current straight and angular lines.
    Last Post: 2012-07-24, 06:03 PM
  5. How to make a section cut that isn't a straight lines?
    By jameswest77 in forum Revit Architecture - General
    Last Post: 2010-10-02, 12:25 AM
Tags for this Thread
