cadtag
Also, check in APPLOAD - look in the Startup Suit -- anything getting loaded there?
then look at the loaded applications list and see whats' being loaded as .mnl or .lsp
I have these in the Startup Suite Contents:
ContourAnnotate.lsp
ENDPIPE.lsp
IDLYR.lsp
matchpolyelev.lsp
ML2.lsp
OSNAPZON.lsp
tlen.lsp
I'm sure none of these are causing a problem. These are all custom lisp routines, but I would have thought there would be more in this list. Under the Loaded Applications list there are many more, some of which are grayed out including the custom lisps noted above. There are a lot of .arx, .crx, .dbx files, and a few .fas and .dll files. All of the .lsp files are grayed out. There is an acad2014.lsp and an acad2014doc.lsp in the list, both of which are grayed out, but no acaddoc.lsp. In the list at the top, the apps which you can choose to be loaded, there is an ADD_ACAD.LSP, but no acaddoc.lsp. I am not able to expand the box, if I could I would take a screen shot so you could look at it.
Here is the contents of the ADD_ACAD.LSP file:
;;Add to your acad.lsp file
(defun rtpanzm_startup (/ cmdecho)
(if
(and
(wcmatch (getvar "PLATFORM") "*Windows*")
(wcmatch (getvar "ACADVER") "*13*")
(progn
(while (not (menucmd "P1.1=?")))
(if (not (menucmd "GRTPANZM.ID_Dummy=?"))
(progn
(setq cmdecho (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(command "_.MENULOAD" "RTPANZM")
(setvar "CMDECHO" cmdecho)
(princ)
(if (and S::STARTUP (listp S::STARTUP))
(setq S::STARTUP (append S::STARTUP '((rtpanzm_startup))))
(defun S::STARTUP () (rtpanzm_startup))
I don't see any .mnl files at all. In the Files of Type drop down box, .mnl is not even shown as a file extension.
I apologize for my lack of knowledge about this, and I appreciate all of your responses.
[Edit] The ADD_ACAD.LSP is not loaded.
