Hello,
I am a new member of AUGI. Could you please provide assistance and advice on an Autosketch (skf) conversion to acad (dwg) problem. For some unknown and frustrating reason some historical Autosketch files will not convert successfully to Autocad editable files. This non-conversion problem occurs on a few hundred drawings which have been created on various versions of Autosketch, however, since we use Autosketch 10 it should be safe to assume backwards compatibility for the software !
I have attached a doc file which shows the problem.
We currently use Autosketch 10, which we have discovered is no longer supported by Autodesk, however, I cannot believe Autodesk have basically abandoned the software without fixes or assistance for Autosketch. I understand that there maybe issues concerning the Windows platform versions used for the various versions of Autosketch – however, I am hoping there is an easier way to resolve this problem.
Any advice, help or solutions would be greatly appreciated ?
Thankyou for your assistance in advance !
