Thread: Viewing point clouds in R15
    2014-08
    Default Viewing point clouds in R15
    I've tried nearly everything to visualize point clouds in R15 - no joy.
    Steps I have done:
    1.started a new Revit 2015 project
    2. indexed a .Las file
    3. Linked the corresponding .rcs and .rcp files
    4. chose positioning - Auto - Center to center
    5. screen is blank!!
    6. Zoom to fit - nothing changes, screen is blank!!
    7. Visibility / Graphic Overrides - > Point clouds: checked
    8. Manage links -> Point clouds: status loaded
    9. 3D view - blank!
    10. 2D view- blank!
    11. changed point cloud color modes -RGB,elevation, intensity - still blank!
    12. saved project and then linked to another - still blank!
    Any ideas? Is there a problem with R15 displaying point clouds?
    Thanks for the help.
    Cheers,
    Paul
    2008-12
    6
    Default Re: Viewing point clouds in R15
    I got the same issue.I tried both rcp and rcs files.
    I can window select the file but is not visible in any view.
    2006-12
    101
    View Ranges? Section Boxes? Cropping?
    One outlying point a million miles away from the others, so that when you zoom extents, all you see is 2 black pixels separated by the whole screen?
  1. 3D Solid with Point Clouds
    Last Post: 2013-11-18, 11:54 AM
  2. 2014: What are Point Clouds?
    By FBL - Desirea in forum AutoCAD Civil 3D - General
    Last Post: 2013-10-29, 08:51 PM
  3. 2014: Point clouds
    By batproj in forum Revit Architecture - General
    Last Post: 2013-10-14, 04:26 PM
  4. Using Presenter with Point Clouds
    By lhuynh930530 in forum NavisWorks - General
    Last Post: 2012-03-15, 03:21 PM
  5. Handling point clouds
    By Curly in forum AutoCAD Civil 3D - General
    Last Post: 2011-03-23, 03:41 PM
