Results 1 to 7 of 7
Thread: Elevation and section markers by phase
    2002-09
    Madison, WI
    5,688
    Default Elevation and section markers by phase
    So I have an elevation marker created in an early phase is there a way to get the view to show up in later phases without using a referenced view? Ie are Eleavtions and Sections phase specific and only show up on plans of the same phase.
    Thanks in advance.
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Elevation and section markers by phase
    No simply because elevations don't have a phase, they are the phase. They don't exist in time since they are displaying a point in time.
    2002-09
    Madison, WI
    5,688
    Thanks. It makes sense. Just like rooms do. We'll just have to use the reference other view method I guess.
    Gee, wouldn't it be nice to have a toggle that says this view is good from this point in time going forward. You build the outside first. Once it's built, odds are you're not going to remodel it before construction is complete.
    2015-11
    Madison, WI
    1,318
    But you can push and pull that information around by using the Phase of the view. We have a hospital project, that was one phase but is now being broken into three new construction phases. A lot of the work was already done, but now needed to be broken up by phase. Instead of whole sale recreating the views and all the annotations. We duplicated the plan & elevation views, and removed the annotation of things happening in a future phase. Once you change the phase of the duplicated view, the new work shows up and the annotation is there to cover it. There were also a lot of callouts for enlarged plan views. These callouts were just shifted to the proper phase (when the work actually was to happen) and everything worked out fine.
    Cheers,
    Jeff S.
    2002-09
    Madison, WI
    5,688
    Right.
    Problem here is we're doing a Phased project but we aren't issuing phased drawings.
    So while I know where and when the work is going to happen I'm only going to show you the final condition for the most part.
    So while the work took place in phase 1, I'm showing the completed work at the end of phase 20.
    Makes lots of sense doesn't it?
    2005-07
    3,792
    Im curious David, why did you break it down in Revit of your not doing the documentation based on those phase?
    2002-09
    Madison, WI
    5,688
    Simple answer is it wasn't in our contract. Ha.
    That's the way the owner wanted it and it didn't take long before the contractor threw the hands up and started asking for phasing drawings.
  1. Need Plan Markers like Section Markers
    By Chirag Dedhia in forum Revit - Platform
    Last Post: 2009-03-24, 12:13 PM
  2. elevation and section markers
    By heather.ward-walton in forum Revit Architecture - General
    Last Post: 2008-04-20, 05:08 AM
  3. Elevation Markers
    By Chris.N in forum Dynamic Blocks - Technical
    Last Post: 2006-03-15, 02:46 PM
  4. Section & Elevation markers visibility
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2003-12-07, 09:14 PM
  5. Section markers out of phase
    By beegee in forum Revit Architecture - General
    Last Post: 2003-06-10, 05:47 AM
