Thread: Converting Imperial to Metric Pipe Systems
    2013-09
    15
    Default Converting Imperial to Metric Pipe Systems
    I am working on a job in Egypt. Normally I do jobs here in the States, so I am used to doing everything in Imperial. I have successfully converted my drawing over to Metric with everything(ie: dimensions, elevations, etc.) except for the pipe sizes. I have only drawn a small amount of pipe so far, so I don't mind redrawing what I have already done. My issue is getting the system template into the Metric Catalog. Is there a way to copy a system that I have already set up with all the fittings, and button mapping done from the Imperial Catalog to the Metric Catalog? I have 12 systems on the job and would hate to have to recreate all of these systems over again. Any advice will be much appreciated.
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    569
    Default Re: Converting Imperial to Metric Pipe Systems
    The Imperial and Metric databases are totally separate. They are not interchangeable.
    Easiest way is to draw in imperial then annotate everything Metric.
  1. 2014: Converting AutoCAD .pat file from Imperial to Metric
    By kmarquis in forum Revit Architecture - General
    Last Post: 2013-07-26, 10:44 PM
  2. Converting Metric to Imperial DWG
    By spatterson in forum AutoCAD Civil 3D - Survey
    Last Post: 2010-10-05, 05:34 PM
  3. Converting file from IMPERIAL to METRIC
    By Openwheeler in forum AutoCAD General
    Last Post: 2008-07-18, 01:06 PM
  4. Converting Imperial to Metric
    By jbrazier in forum Revit Structure - Families
    Last Post: 2007-09-27, 08:05 PM
  5. Converting Downloads from imperial to metric
    By Kelvin in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-01-09, 08:00 AM
