I'm trying to find a simple solution where my users can generate new files from templates that include the sheet border size they need which is externally referenced as a relative path attachment. The reason I need it to be a relative attachment is because I need the border to reside in the same folder where the sheet drawings and xref's are located (all in a single folder). I prefer not to have the xref point to a fixed location on the server but rather it point to its own project folder. I can configure almost all of what I want to do but one problem. The new file is created from this template is saved into a newly created empty folder where the border xref does not yet exist. The xref border would need to be manually copied into this folder to properly be recognized and loaded. After a reload, everything works fine from that point forward. Any new sheets generated from a template for that border size (filename) will resolve properly. I'm trying to eliminate that one last task of having my user manually copy the border from a source location into this new folder. Is there a way to somehow wblock or export the border userd into the folder I'm saving the new file? Hope this all makes sense.
