Results 1 to 7 of 7
Thread: Help - Need Autolisp program (create a boundary on specific offset, change layer and properties)
    2007-11
    Pune
    36
    Question Help - Need Autolisp program (create a boundary on specific offset, change layer and properties)
    Hello All
    I need a help on following task.
    1. create a polyline on specific offset from closed area.
    We can use 'Boundary' command but i want a offset in inner side of area. offset is fixed.
    2. polyline change some fixed property. e.g. layer, color , line weight (can not set for layer)
    3. created polyline joints with fillet with fixed radius.
    Please find attached image for more details.
    Thanks & Regards
    Yogesh
    2007-11
    Pune
    36
    Default Re: Help - Need Autolisp program (create a boundary on specific offset, change layer and properties)
    Hello all
    Can anybody give me a program at least for first step?
    Regards
    Yogesh
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by SunYog View Post
    Hello all
    Regards
    Yogesh
    Offset towards centroid (will work unless it's an extremely irregular object) then fillet with polyline option.
    2007-11
    Pune
    36
    Thanks a lot for fast reply..
    sorry but i really not understood about 'offset towards centroid', offset has only following options
    Command: offset
    Current settings: Erase source=No  Layer=Source  OFFSETGAPTYPE=0
    Specify offset distance or [Through/Erase/Layer] <Through>:
    and boundary has as per attached dialog box(boundary.jpg). Sorry to say could you please tell me again the way. Please find attached pattern (01.jpg) .. and size of DWG is A0
    and basic form (white lines) are 'line' not polylines.
    Thanks & Regards
    YP
    Tallahassee, FL USA
    3,667
    Command: offset
    Thanks & Regards
    YP
    Have you done any lisp?
    Since you need to create a boundary first the lisp should start by prompting for and storing a pick point inside that can be used by both the boundary and offset commands. Prompt for and set the offset distance. Use command calls with the same options as you would use on the command line.
    2014-02
    5
    Here is my code for picksf.lsp; my program to use the boundary command to read the square footage of a room....
    The boundary is a one line command.... You are also picking a point, for the boundary (variable p1), so the same point should be usable for the offset command... I make the layers I want at the beginning of my code and set clayer to use them... You can kill the area, totaling, and text stuff... Maybe even kill the loop... and add the offset command....
    (defun c:picksf()
    	(setq tot 0)
    	(setq p1 (getpoint "\nPick inside room:"))
    	(command "-layer" "n" "area-mask,area" "p" "n" "area-mask" "")
    	(while (/= p1 nil)
    		;do boundary, and read its area, then label sf and add to tot
    		(setvar "clayer" "area-mask")
    		(command "-boundary" p1 "")
    		(setvar "clayer" "area")
    		(command "area" "ob" "l")
    		(setq a1 (getvar "area"))
    		(setq tot (+ tot a1))
    		(command "-text" p1 "0" (strcat (rtos tot 2 2)  " SF"))
    	(setq p1 (getpoint "\nTotal Label location:"))
    	(princ (strcat "Total Area = " (rtos tot 2 2) " SF"))
    	(command "-text" p1 "0" (strcat (rtos tot 2 0)  " SF") "")
    2001-12
    St. Louis
    5,407
    Just to keep it easy to read, remember in the future to click the "Go Advanced" button (which comes up after hitting one of the reply buttons) and use the code tags available in the bottom right of this screen cap...
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Autolisp program to label station and offset.
    By aaronic_abacus in forum AutoLISP
    Last Post: 2020-09-16, 01:36 AM
  2. Replies: 7
    Last Post: 2013-06-04, 04:01 PM
  3. View/Change Properties in Layer Properties Window
    By mlongfellow in forum AutoCAD General
    Last Post: 2007-12-28, 03:37 PM
  4. Change display of layer without changing layer properties
    Last Post: 2006-09-11, 02:33 PM
  5. offset or copy AND change to current layer
    By mpriest in forum AutoCAD Customization
    Last Post: 2005-04-22, 06:08 PM
