Lance. Here you go...
; List of Defined Functions
; C:GD C:VPSC DXF ENDERR GETMODE INITERR MVGUIDE
; SCLTXT SETMODE VPDTA VPSC
; MVGUIDE - main routine
(defun mvguide (/ ctr dx dy fl p1 p2 p3 p4 scl vno vpinf xc xsz yc ysz)
(setq
vpinf (vpdta "which requires guideline")
fl (nth 0 vpinf)
vno (nth 1 vpinf)
ctr (nth 2 vpinf)
scl (nth 4 vpinf)
xsz (nth 5 vpinf)
ysz (nth 6 vpinf)
xc (car ctr)
yc (cadr ctr)
dx (* xsz scl 0.5)
dy (* ysz scl 0.5)
p1 (list (- xc dx) (- yc dy))
p2 (list (+ xc dx) (- yc dy))
p3 (list (+ xc dx) (+ yc dy))
p4 (list (- xc dx) (+ yc dy))
(command
"MSPACE"
"LAYER" "M" "VPORT" ""
"PLINE" p1 "W" 0 0 p2 p3 p4 "C"
"CHANGE" (entlast) "" "P" "LA" "VPORT" ""
(if fl (command "PSPACE"))
(if (= "11" (substr (getvar "ACADVER") 1 2))
(princ (strcat "\nScale of Viewport #" (itoa vno) " is " (scltxt scl)))
(alert
(strcat
"Scale of Viewport #" (itoa vno) " is 1:"
(if (= scl (fix scl)) (itoa (fix scl)) (rtos scl 2 3))
; C:GD - command line access to function
(defun C:viewgd ()
(initerr)
(setq prgmod (getmode '("TILEMODE" "CLAYER" "OSMODE")))
(setvar "OSMODE" 0)
(mvguide)
(setmode prgmod)
(enderr)
(princ)
; VPSC - find scale of Viewport
(defun vpsc (/ fl scl str vno vpinf)
(setq
vpinf (vpdta "for which scale required")
fl (nth 0 vpinf)
vno (nth 1 vpinf)
scl (nth 4 vpinf)
str (strcat "Scale of Viewport #" (itoa vno) " is " (scltxt scl))
(princ (strcat "\n" str))
(alert str)
(command (if fl "PSPACE" "MSPACE"))
; C:VPSC - command line access to function
(defun C:VPSC ()
(initerr)
(setq prgmod (getmode '("TILEMODE" "CLAYER")))
(setvar "OSMODE" 0)
(vpsc)
(setmode prgmod)
(enderr)
(princ)
; VPDTA - select viewport and return data
(defun vpdta (prom / cnt ctr cvp en flag scl ss vno vsz xsz ysz)
(if (= (getvar "TILEMODE") 1)
(progn
(setvar "TILEMODE" 0)
(command "PSPACE")
(if (/= (getvar "CVPORT") 1)
(setq flag nil)
(progn
(setq flag T)
(command "MSPACE")
(getpoint (strcat "\nPick twice in Viewport " prom "\n"))
(setq
ctr (getvar "VIEWCTR") ;centrepoint of viewport
vsz (getvar "VIEWSIZE") ;height of viewport
vno (getvar "CVPORT") ;no. of current viewport
(command "PSPACE")
(setq
ss (ssget "X" '((0 . "VIEWPORT")))
cnt -1
(while (and cnt (< (setq cnt (1+ cnt)) (sslength ss)))
(setq en (entget (ssname ss cnt)))
(if (= (dxf 69 en) vno) (setq cnt nil))
(setq
xsz (dxf 40 en)
ysz (dxf 41 en)
scl (/ vsz ysz)
(if (not flag) (command "MSPACE"))
(if (/= (dxf 8 en) "VP") (entmod (subst (cons 8 "VP") (assoc 8 en) en)))
(list flag vno ctr vsz scl xsz ysz)
; SCLTXT - convert scale factor to common text forms
(defun scltxt (scl / dimz lup txtscl)
(setq dimz (getvar "DIMZIN") lup (getvar "LUPREC"))
(if (not scl) (setq scl (getvar "DIMSCALE")))
(if (< (abs (- scl (fix (+ scl 0.002)))) 0.001)
(setq scl (fix (+ scl 0.002)))
(if (= (getvar "LUNITS") 4)
(setvar "LUPREC" (cond ((> scl 192) 5) ((> scl 96) 4) (T 3)))
(if scl
(if (member scl (list 4 8 12 16 24 32 48 64 96 192 384)) ;Architectural scales
(setq txtscl (strcat (rtos (/ 12.0 scl)) "=1'-0\""))
(if (member scl (list 120 240 360 480 600 720 900 1200 1800 2400 3000 6000))
(progn ;Engineering scales
(setvar "DIMZIN" 0)
(setq txtscl (strcat "1\"=" (rtos scl)))
(setvar "DIMZIN" dimz)
(setq txtscl ;all others including metric, full & half scale
(cond
((= scl 1) "FULL")
((= scl 2) "HALF")
(T (strcat "1:" (rtos scl 2 2)));if more precision needed, change last 2
(setq txtscl "not defined")
(setvar "LUPREC" lup)
txtscl
; GETMODE - establish changeable variables which are to be reset
; at end of program and initialize error program
(defun getmode (mod1 / mod)
(repeat (length mod1)
(setq
mod (append mod (list (list (car mod1) (getvar (car mod1)))))
mod1 (cdr mod1)
mod
; SETMODE - reset variables and error system
(defun setmode (mod1)
(setvar (caar mod1) (cadar mod1))
(setq mod1 (cdr mod1))
; DXF - extract DXF code from list
(defun dxf (code elist) (cdr (assoc code elist)))
; INITERR - set up error at start of program
(defun initerr ()
(setq
olderr *error*
*error* gderr
errmod (getmode '("BLIPMODE""CMDECHO""MENUECHO""ORTHOMODE""OSMODE""SNAPMODE"))
(setvar "CMDECHO" 0)
(command "_.UNDO" "G")
; ENDERR - clean up error at end of program
(defun enderr ()
(command "CMDECHO" 0)
(if errmod (setmode errmod))
(setq
errmod nil
prgmod nil
libmod nil
(command "_.UNDO" "E")
(setq *error* olderr)
; *ERROR* - main error routine
(defun gderr (msg)
(command nil nil nil)
(reset msg)
(grtext)
(if (and (/= msg"console break")(/= msg "Function cancelled"))
(grtext -1 "Program ERROR")
(princ)
; RESET - clean up after error
(defun reset (msg / x)
(if msg
(if (and (/= msg "console break")(/= msg "Function cancelled"))
(prompt (strcat "Error: " msg "\n"))
(prompt (strcat msg "\n"))
(prompt"\nResetting environment...")
(command "UNDO" "E")
(command "U")
(if prgmod (setmode prgmod))
(if libmod (setmode libmod))
(if blkmod (setmode blkmod))
(setq
errmod nil
prgmod nil
libmod nil
blkmod nil
(princ)
(princ "\nVIEWGD loaded. Type VIEWGD to make guide. Type VPSC to display scale.")
(princ)
