Thread: Inserting general notes onto sheets from a work (.doc) document
    2011-02
    15
    Default Inserting general notes onto sheets from a work (.doc) document
    I am having difficulty here inserting the general notes. We are using Autocad 2014 and are cut and pastings the text from the .doc using the windows cut & paste command into the mtext editor. There are some formating issues with the indents and such. However when I dress up the text then end the drawing it actually moves a margin over and makes the note longer.
    Just how do I save this note with the dressed up margins so it stays as I placed them?
    Mark
    2015-10
    Colorado Springs, CO
    369
    Default Re: Inserting general notes onto sheets from a work (.doc) document
    I can't help with what you are doing now...
    But one thing to remember is that AutoCAD is not a word processor... and as such won't always play nice with your pasted stuff from word. I've found that there are add on programs that link and keep formatting nicely. I use AutoWord from Cadig right now, but there are others.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Try Paste Special as AutoCAD Entites. Don't have it open now, but I've done it before. Not sure if rtext will work on a Word doc.
    2015-08
    Eastern Iowa
    87
    I don't know if this will work in your situation, but we have our general notes set up as blocks that can be inserted with a base point - the less word processor, the better. Good luck to you!
  1. General Notes/ Plan Notes/ Sheet Notes
    By ubviswa in forum Revit Structure - General
    Last Post: 2012-12-04, 05:32 PM
  2. General Notes
    By lbeyer593018 in forum Revit Structure - General
    Last Post: 2012-09-10, 07:55 PM
  3. General Notes / Key Notes
    By lonewolfjustin in forum Revit MEP - General
    Last Post: 2008-11-25, 02:31 AM
  4. General Notes
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2005-03-16, 09:45 PM
  5. General Notes
    By rflores.73491 in forum AutoCAD General
    Last Post: 2004-09-10, 07:25 PM
