Thread: DB apperance depending on attribute value
    2009-01
    Warsaw Poland
    130
    Default DB apperance depending on attribute value
    Hi there!
    I'm wondering if there is a possibility to change block apperance (for example dimensions) by attribute value?
    For example lets say that I have DB with just linear stretch and I want my DB to read stretch value from attribute value. If YES, Then I'm able to export/import attributes and automaticaly change dimensions of multiple blocks.
    possible?
    BR
    Maciek
    2009-01
    Warsaw Poland
    130
    Default Re: DB apperance depending on attribute value
    I've prepared test DB block to show what I would like to achieve.
    Block contains two attributes (lenght_att, height_att) and two streatch actions based on two parameters (lenght_parameter, height_parameter).
    Because I have attributes I have possibility to do export/import attribute data. And I would like sth to read/write attributes value into parameters value:
    lenght_att >>> lenght_parameter
    height_att >>> height_parameter
    www.cadforum.cz/forum_en/uploads/38935/test.dwg
  1. DB apperance depending on attribute value
    By Macieto in forum AutoLISP
    Last Post: 2014-10-14, 07:19 AM
  2. Load dll depending on dwg name?
    By amaser in forum Dot Net API
    Last Post: 2011-04-18, 02:14 PM
  3. Rendering Apperance in 3D Max Design 2009
    By tenghui2000 in forum Revit - Rendering
    Last Post: 2008-07-22, 01:42 PM
  4. Size Attribute depending on the DIMSCALE variable?
    By Dave F. in forum Dynamic Blocks - Technical
    Last Post: 2008-05-30, 09:06 PM
  5. Replies: 7
    Last Post: 2008-01-29, 06:11 PM
