Wish List System
Summary: Like in GIS software where you can see data displayed based on the visual scale, I would like the same to be applied to layers which will help save time from constant Freezing and Thawing of Viewports at different scales.
Description: Imagine when creating/modifying a layer so that it can be set to display within Viewports ONLY at Particular scales.
For example, if you are creating an overall civil Site Plan at a large scale, there is [typically] no need for the underground infrastructure to be displayed.
It would be productive if in the Layer Manager that you can highlight a series of layers that you do not want displayed after a certain scale factor, right-click, and then assign a "display layers up to" a certain viewport scale value, so when you create a new viewport (or modify the scale factor of an existing VP) those layers will automatically be "off" after a certain scale factor.
Of course, all the regular layer control options via a Viewport will still be available.
Product and Feature: AutoCAD - Layer
Submitted By: Murray Clack on 10/22/2014
