Summary: Stop messing with the look of the interface, fix the program.
Description: Stop spending time messing with the appearance of the interface!
Do not take away interface options needlessly! ie forcing status bar icons only when most users had these set to text.
Focus on fixing bugs and issues with the API. If Autodesk wants to force those programming for their products to use Dot Net then fix the issues in it that are forcing them to go back to LISP to get the job done.
For example, I have a number of cases open with them regarding broken or incomplete functionality in Dot Net or in MEP itself.
From 7/13/2011 - Piping - MEP forces a minimum pipe length between fittings which cannot be controlled by the user
From 7/17/2012 - LabelCurves - They sometimes move to unexpected locations when moved
From 2/24/2014 - Adding Wire - Missing functions to add wire according to wire style settings. This is the one that I had to call a LISP function from Dot Net to finish the program.
Product and Feature: AutoCAD - Other
Submitted By: John Shimkus on 10/22/2014
