Results 1 to 7 of 7
Thread: Text layer
    Wish List Administration
    2011-08
    4,581
    Default Text layer
    Summary: Automatically set layer of text to specified layer!
    Description: When Mtext is selected automatically set it to a specified layer, such as S-Text in my case.
    Product and Feature: AutoCAD Architecture - AEC Dimensions
    Submitted By: Ralph Stephens on 10/22/2014
    2009-11
    5,761
    Default Re: Text layer
    Quote Originally Posted by Wish List System View Post
    I simple Visual LISP Command Reactor can do this already.
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2003-03
    Philadelphia, PA
    2,392
    You can create a Tool Palette tool that will allow you to start the MText command with a layer key. That tool can then be referenced by a ribbon tool, if you want.
    2009-11
    5,761
    Quote Originally Posted by dkoch View Post
    ... Just not from Command Line; for completeness.
    Computer Specs:
    2003-03
    Philadelphia, PA
    2,392
    Quote Originally Posted by BlackBox View Post
    True. It is possible to access layer keys from AutoLISP, so you could write a bit of code that sets the layer and then runs the MText command. I had done that in the past, but do recall some issues with being able to reset the layer at the end, since the routine only started the MText command, and then ended, so as not to have to funnel user input through the LISP routine. We just lived with it not restoring the old layer.
    Using a reactor avoids all of those issues; I am just leery of reactor programs, because a poorly written one can really mess up a file/workflow.
    2011-08
    4,581
    Exclamation Re: Text layer
    Text layer
    2011-08
    4,581
    This wish has been reported as granted and already in the software.
  1. Replies: 12
    Last Post: 2016-04-19, 06:09 PM
  2. Replies: 7
    Last Post: 2014-06-04, 09:00 AM
  3. Replies: 3
    Last Post: 2012-12-19, 03:00 PM
  4. 2013: Text on wrong layer
    By jones129 in forum AMEP General
    Last Post: 2012-11-06, 09:19 PM
  5. Layer is OFF but Text still displays
    By smdin79 in forum AutoCAD LT - General
    Last Post: 2004-08-11, 06:19 PM
