Thread: "Demote" Data Shortcuts
    2008-01
    Taxachusetts
    68
    Default "Demote" Data Shortcuts
    I have a file with about 18 data ref'd alignments. When I opened it up this morning, ALL of the data refs had been promoted and nobody in the office will fess up. This file has alignment labels up the wazoo, so deleting, re-referencing, and re-labeling is pretty much out of the question. Is there any way to force the alignments to call back to their source drawing?
    5,719
    Default Re: "Demote" Data Shortcuts
    Quote Originally Posted by scott.jeffers View Post
    Well, the quickest way is to simply restore the drawing from yesterday's (or prior) backup, no?
    [Insert reference to cadtag's AU course here]
    2008-01
    Taxachusetts
    68
    I just walked through 20 day's worth of backups. It's been like this for quite a while. Don't blame me; I was on vacation!!
    5,719
    Without the ability to restore a copy from backup, I'm afraid that what little I know of C3D .NET API does not suggest this is possible; perhaps someone smarter than I can educate us both.
    Cheers
    2008-01
    Taxachusetts
    68
    Update: Problem solved (a while ago). Half of the office was on 2013 and the other half was on 2014. Although they are technically the same generation file format, data shortcuts, once opened with 2014, will show as promoted in 2013. This is a known Civ 3D bug. I guess it's on of those UPGRADE, OR ELSE deals.
    5,719
    Glad you got it sorted, and thanks for posting the cause - I also hope you're not responsible for rolling out the mixed-version environment, without first testing the cross-version functionality. Haha *yikes*
    Cheers
  1. Replies: 4
    Last Post: 2014-01-01, 07:58 PM
  2. Replies: 0
  3. New "Keyboard Shortcuts" Text File Location
    By Shaylon Vaughn in forum Revit Structure - General
    Last Post: 2009-10-29, 04:33 PM
  4. Ability to assign shortcuts to the "Command Options" in the Option Bar
    Last Post: 2009-01-31, 04:01 PM
  5. Keyboard Shortcuts - OSNAP commands with the "F" keys
    By mvanstone in forum AutoCAD CUI Menus
    Last Post: 2005-12-21, 04:04 PM
