Summary: Fix "VP Color" setting so that VP Color stays when "HIDE" command is given in a viewport containing a 3D model.
Description: My “wish” is for the VPCOLOR setting to work correctly. At the moment, and with previous releases, VPCOLOR does not work in a viewport when the "HIDE" command is used on a 3D model.
Example,
Layer 1 is set to color 1 ---- and VP Color for layer 1 is set to color 2
A 3D model "in viewport" is on layer 1 and displays VP Color which is set to color 2 in that viewport - ie "a yellow object" is displayed in the viewport.
Run the hide command - what happens? The 3D model has not retained the VP Color which is set to color 2 - but the hidden line 3D model displays the main layer colour which in this example is color 1.... The 3D model which we ran the HIDE command on should be displayed in the VP Color setting which in this example is color 2.
Product and Feature: AutoCAD - 3D
Submitted By: Jim Stapenell on 10/22/2014
