Thread: Finish Copy/Monitor to work with ALL column grid type, single and multi-segment
    Wish List Administration
    2011-08
    4,581
    Default Finish Copy/Monitor to work with ALL column grid type, single and multi-segment
    Summary: With the addition of Multi-segment column grids the Copy/Monitor command does not support these new grid types. This prevents the users in a large site/project from using a set of "central" grid files, secure them from normal user changes, to link and Copy/Monitor into all the routed systems models. This is needed to assure consistency/accuracy across a large enterprise.
    Description: With the addition of Multi-segment column grids the Copy/Monitor command does not support these new grid types. This prevents the users in a large site/project from using a set of "central" grid files, secure them from normal user changes, to link and Copy/Monitor into all the routed systems models. With Revit's current behavior the "grids" need to exist in each model for the automated routing dimensions to function as they should. Just normal linking of a "grid" model doesn't work (another issue as well). With a large number of designers, of varying skill levels involved in the project, this is sorely needed to assure consistency/accuracy across a large enterprise and its long-term support.
    Product and Feature: Revit MEP - MEP Mechanical Routing Solutions - (Mechanical
    Submitted By: Mike Johnson on 10/23/2014
    2007-12
    Exclamation Re: Finish Copy/Monitor to work with ALL column grid type, single and multi-segment
    Yes, I am still waiting for Autodesk to allow multi-segmented grids to be copy/monitored. Just copy/pasting them is not acceptable. That means I have to manually monitor whether these grids changed (moved/renamed/deleted). I have too many projects to worry about such things! Surely Autodesk has the ability to make this happen. Please make it happen!
  1. Copy Monitor Grid Trouble
    By chris.manahan in forum Revit MEP - General
    Last Post: 2018-06-05, 12:00 PM
  2. AB228-9P: Beyond Copy/Monitor: Working on a Single Revit® Central File Over the WAN
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:55 PM
  3. 2013: Copy/Monitor Multi-Segmented Grids
    By mvalencia25 in forum Revit MEP - General
    Last Post: 2012-07-18, 09:50 PM
  4. Copy Monitor & Grid Extents
    By krish.d.rao in forum Revit Architecture - General
    Last Post: 2010-08-04, 06:56 PM
  5. Copy / Monitor Structural Column - Blue Dot?
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-01-29, 09:03 AM
