Thread: Picking end points on 3d objects
    Default Picking end points on 3d objects
    Hello all,
    been a long time since I browsed these forums...I see alot of updates! Anyways, I've upgraded to ACAD 2013, and I'm having trouble picking end points of 3d rectangles now. even in a wireframe view. Can anyone point me in the right direction, as to what to check?
    Thanks!
    2001-12
    St. Louis
    5,408
    Default Re: Picking end points on 3d objects
    Quote Originally Posted by balcomwoodworks164944 View Post
    Hello all,
    Thanks!
    This is a little off-topic, but, if you previously had an AUGI account, please feel free to reach out to membership@augi.com and you can have your old account merged with your new one.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    0,0,0 The Origin
    8,570
    What do you mean by a "3d rectangle"? A brick?
    Is it made of surfaces or a solid or 2d geometry with thickness?
    ENDpoint snap should pick a corner of a solid.
    2006-02
    Houston
    29
    If you are trying to pick an endpoint of a 3d object while in paperspace and the vport is hidden then you could have a problem. (Do not pick while hidden)
    If you are in model space then I would have no idea why you couldn't pick endpoint.
  1. Draw rectangles by picking 3 points
    Last Post: 2014-10-27, 09:25 PM
  2. Replies: 2
    Last Post: 2011-07-22, 05:32 AM
  3. Define a print area by picking two points
    Last Post: 2007-09-27, 08:00 AM
  4. Picking points in order to create a point group in Civil 3D 2007
    By wcarter in forum AutoCAD Civil 3D - General
    Last Post: 2006-11-03, 08:34 PM
  5. Can you make family & place width by picking two points?
    By rgesner in forum Revit Architecture - Families
    Last Post: 2005-12-22, 07:44 AM
