Thread: Reference Library
    2012-11
    Brisbane, Australia
    239
    Default Reference Library
    Hey All
    I thought I would share my block library with you all.
    I have been working on this for quite some time.
    Hopefully you guys find it useful.
    Please Note:
    These blocks have properties that don't have grips.
    you will need to open the property palette to see their full dynamics.
    Cheers
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,542
    Default Re: Reference Library
    Thanks for sharing.
    2004-07
    Baton Rouge, Louisiana
    250
    very nice, the way I would do it if I was allowed at my office, is to create one block on layer 0 for each item (example diff for diffuser), they have allowed me to make a few blocks on layer 0. the layer names shorter (example hsduct for supply duct, we have a command HS which will put you on the layer). our duct turns, transitions, taps and duct are created on layer 0. this allows us to put them on any layer that we want. the duct turns are done using visibility states. here is the basic block called "DUS". it also has single line functiom
    2012-11
    Brisbane, Australia
    239
    Cheers for the feedback mate.
    I cant seem to see your attachment, it just appears as a box with a 1 in it.
    I understand what you mean about the layer 0, the reason the layers are controlled within the blocks are so you can select all your blocks and change the phase.
    It just allows us to convert new blocks to existing easily, it could probably do with some work, i am sure there are better ways that this.
  1. VBA Excel Reference Library
    By mikeheinz09299181 in forum VBA/COM Interop
    Last Post: 2019-09-08, 11:21 PM
  2. Project Workflow: Central content library vs. Project specific library
    By jsteinhauer in forum Revit Architecture - General
    Last Post: 2012-04-18, 01:09 PM
  3. Place detail/section reference cuts on legends that would reference existing details
    Last Post: 2007-09-28, 08:44 PM
  4. Saving New Door To Library & Personal Library
    By SCShell in forum Revit Architecture - General
    Last Post: 2005-05-11, 08:01 PM
  5. Editing the reference keynote library
    By psmith73426 in forum ACA General
    Last Post: 2004-08-31, 08:35 PM
