richards.64879
Only problem is, it still doesn't fix the "bad size" problem with the MTEXT editor.
When the MTEXT editor comes up in one of its "funky" text sizes, for example, the text is so huge that only 10 letters will fit on the entire screen, you can make the text size smaller like this. But the MTEXT window itself stays the same width, so it starts cramming more letters on each line. Net result is you can get the text small enough to see, but it might all be on one line.
Only way around this I've found is to exit the MTEXT editor, zoom the screen (using the mouse scroll-wheel), and then try to edit the text again. Generally, within about five tries, I get a decent text size in the MTEXT editor.
This "feature" of the MTEXT editor is incredibly annoying.
