Results 1 to 10 of 20
Thread: Nudge tool
    Wish List Administration
    2011-08
    4,581
    Default Nudge tool
    Summary: Create a nudge tool that can be used to move things in small increments with the arrow keys.
    Description: Create a nudge tool that can be used to move things in small increments with the arrow keys. This will be helpful with things like annotative text, revision bubbles, viewports, sheet titles etc that don't require numeric precision for placement.
    Product and Feature: AutoCAD Architecture - Tools
    Submitted By: JP Bernier on 11/14/2014
    2011-08
    4,581
    Exclamation Re: Nudge tool
    Nudge tool
    Summary: Create a nudge function which can be used to move things in small increments with the arrow keys after selecting it.
    Description: Create a nudge function which can be used to move things in small increments with the arrow keys after selecting it. This will be helpful with things like annotative text, revision bubbles, viewports, sheet titles etc that don't require numeric precision for placement.
    2009-11
    5,719
    Default Re: Nudge tool
    1+ ... Although, I'd like to see this added to vanilla AutoCAD, and thus all of the verticals that derive from it.
    I can see a plug-in that allows user to define (per-Profile) a Model and Paper space 'nudge' value, where a pseudo-named NUDGE CommandMethod would then filter for Arrow UP, DOWN, LEFT, RIGHT KeyDown events, and 'nudge' the Model, Layout, or Model through activated (and unlocked) Viewport accordingly. Any other key (or perhaps only Enter/Right Mouse Click & Escape?) would exit the Command.
    Not sure that I have the time to do this right now, having just declined a paying consulting job, but a moderate complexity app once I, or someone smarter than I makes the time... Just posting this here for notes to refer back to later.
    Cheers
    Computer Specs:
    2003-03
    Philadelphia, PA
    2,392
    This has been in AutoCAD and its verticals since the 2012 release. Not that I have ever used it for project work. Activate it by CTRL+[arrow key]. As noted in the Help:
    Nudge objects with Snap mode turned off: Objects move two pixels at a time; movement is relative and orthogonal to the screen, regardless of the view direction or the UCS orientation.
    Nudge objects with Snap mode turned on: Objects are moved in increments specified by the current snap spacing; movement is orthogonal to the X and Y axes of the current UCS and relative to the view direction.
    2011-08
    4,581
    Nudge tool
    2011-08
    4,581
    Nudge tool
    2011-08
    4,581
    Nudge tool
    2011-08
    4,581
    Nudge tool
    2009-11
    5,719
    Quote Originally Posted by dkoch View Post
    I actually just stumbled upon this myself, and came back to post... Thanks for saving me the time.
    Still not as complete (IMO), as what I posit, but it has all the ground work in place... I'll try to remember to request it in 2016 Alpha/Beta.
    Now, if only I were getting emails when posts have been added to threads I am subscribed to....
    Computer Specs:
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Quote Originally Posted by BlackBox View Post
    I haven't ever quite figured out how to make that work ... but I wonder if the wish list threads might be different ... kinda like CWC posts.
  1. Revit Nudge tool
    By Damo in forum Revit Architecture - General
    Last Post: 2005-01-14, 03:31 AM
  2. Nudge doesn't Nudge right when used within a Rotated View on a Sheet...
    By hand471037 in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2005-01-13, 07:55 AM
  3. Nudge doesn't Nudge right when used within a Rotated View on a Sheet...
    By hand471037 in forum Revit Architecture - General
  4. Nudge
    By Andre Baros in forum Revit Architecture - General
    Last Post: 2004-02-01, 02:06 AM
